ProCharger surge valve and hose delete?
Old 07-03-2006, 01:30 PM
11 Second Truck Club
Superado's Avatar
Originally Posted by ranwalk
Yes, mine is vacumn onperated , it has a line going to it.
I'll have to shorten the hose from the "T", moving the valve closer to it, then install the filter so that I can run the vacuum line to the valve under the head unit like yours. Currently, mine is running over the top to the valve, which sits just in front of and to the right of the head unit.
Thanks again...
I'll post pics of the new intake mod and the surge VTA filter when I complete it.
Old 07-03-2006, 04:56 PM
Superado's Avatar
Hey guys, check out the last post I made here:
https://www.performancetrucks.net/fo...d.php?t=362214
the intake fabrication is awesome and the surge being VTA is another great pic, this valve is like the one on mine.
Old 07-05-2006, 11:28 AM
Superado's Avatar
Here's pics of what I ended up with...
http://pg.photos.yahoo.com/ph/al_101...1264/my_photos
And yes, that is my FMU still hooked up, just unattached from the firewall...
Old 07-06-2006, 09:22 AM
Superado's Avatar
Throttle response is MUCH better...
Old 07-06-2006, 11:32 PM
2lugnuts's Avatar
Is it louder when it blows into the atmosphere? That allen head on topof surge have any of ya'll adjusted that any?
I have an oily residue to on top of my Charger sometimes, I do not know where this is coming from.
I think I have to send my Charger off again because know its making a different noise than that bearing noise that it usually makes at idle, all my oil levels are fine and boost is good but makes random noise like bearing sticks than releases.
Old 07-07-2006, 07:40 AM
Superado's Avatar
Doesn't seem to be.
That allen head on top of surge have any of ya'll adjusted that any?
I haven't, that must be the black one like ranwalk's, mine is different type of adjustment bolt.
In regards to the noise, I would be willing to bet that it is the idler pulleys, I went thru 2 sets before changing my stock tensioner and stock idler along with new ATI idlers and solved it.
SlvrSierra4.8
10-01-2015 09:39 PM
chopperloco
09-28-2015 08:40 AM
lxcoupe
09-11-2015 03:17 PM
00loudchevy
09-11-2015 07:55 AM
Justin87gn
09-10-2015 12:06 PM
Quick Reply: ProCharger surge valve and hose delete?
