the procharger thread
02 w/ lowest mileage 2800
408 with lunati rotating assembly, 8.5:1, Stage III 6.0 heads, Comp 234/244 .576/.596 114+4
First Setup: P1SC 3.4 pulley 11psi 60lb/hr injectors 520rwhp @5500rpm 520rwtq @4400 no intercooler meth only
Secong Setup: D1SC 3.4 pulley 17psi 80lb/hr injectors 700rwhp @6000 w/ belt slip no intercooler meth only
New setup still in the works: F1C 8.25 lower 4.75 upper pulley front mount intercooler dedicated 12 rib drive
I don't think the Procharger unit it self is different it's just the mounting bracket.
IE if you find a D1 for a Ford all you need to get is the bracket for your vehicle..
not positive but that was my understanding, someone correct me if I am way off in left field.
Baltimore Whore
This is tru, unless it is a opp rotation unit. Also always remember that where ever the tag is on the unit, it always has to be facing up at you. That is where the oil slinger is located, as it has 3 positions, can be reclocked.
