the procharger thread
Old 05-14-2012 | 07:06 PM
  #21
Pc2000trk's Avatar
5.3,Milled & worked 243 heads , compcam 227/243 .614 .624 114 , d-1 17lbs at 6400 low timing do to knock sensor was bad , e-85 , 103lb inj ,long tubes , 4l60 , 4200 converter
Made 590rwhp
It's a street truck so only track times I had a best of 11.80's lifting at the 1000' mark on a radial with the rev limiter low and the same timing it was dynoed on
It has more in it - gonna take it to 6800 with more timing , and if im not happy after that I'll grab the button lol
Old 05-14-2012 | 07:10 PM
  #22
ak2007r6's Avatar
Made 590rwhp
It's a street truck so only track times I had a best of 11.80's on a radial with the rev limiter low and the same timing it was dynoed on
Damn that sounds like a fun truck. I want to build the motor up a little more than want to get up into the teens for boost.
Old 05-14-2012 | 07:56 PM
  #23
Pc2000trk's Avatar
That's why I run e-85
Old 05-14-2012 | 08:14 PM
  #24
ak2007r6's Avatar
Would love to if they ever offered it in my state
Old 05-14-2012 | 10:26 PM
  #25
CCrowell2's Avatar
I have 1997 chevy scsb and i still have the the vortec 5.7 in it. I was wonder if they make a D1 that fits my motor but the discharge side points towards the fire wall so I can keep my same intercooler setup and ditch the whipple that only makes 8-9psi. My motor was built for boost and would like to run 14-15psi. Any info would be great thank Chase.
Old 05-14-2012 | 10:57 PM
  #26
ak2007r6's Avatar
They make a kit but it's the P1 so you would have to custom order it with the D1.
From their site
Old 05-14-2012 | 11:00 PM
  #27
Mangled03gmc's Avatar
Baltimore Whore
They make kits for that year truck, it goes in the same location as all the ones for 99-12 trucks. But the brackets are different as well as the clocking of the blower. They sit slightly at a angle as to where ours sit strait up and down.
Old 05-15-2012 | 01:56 AM
  #28
CCrowell2's Avatar
Thanks guys, just trying to figure out a way to keep my air/water intercooler setup the way it is and run a D1.
Old 05-15-2012 | 03:13 PM
  #29
BoostFreak's Avatar
376 LS3
CNC L92's
Blower Cam
Kooks/Magnaflow
HoB Dedicated 8-Rib D-1SC
RPM Level 6 Trans
Precision 3200
Old 05-15-2012 | 04:16 PM
  #30
Nightmare04's Avatar
6.0 Lq9
Vortech V2 #9 (basically P1)
227/234 600/620 118
Built 80e 3600 Stall 3.42 gears
1.70 60ft 7.55 1/8th 90 MPH
