ProCharger vs. Rear Mount for DD/towing
I need some opinions based on personal experience and where better to find it than here...
First off, I am a college student and this is my daily transportation. My 5.3 is pretty much stock with 78,XXX miles on it. I tow my bass boat quite often during the summer months, around 4-6 times a week, but very seldom through fall/spring. I also hunt out of the truck so it does see off-road, and I drive dirt roads fairly often when I am home, probably 15% of the time. I am aware of majority of the upgrades that I am going to have to do to the drivetrain and fuel system, which will be the same for either application for the most part.
I have been planning on doing a ProCharger setup for awhile now; I have already bought the mounting bracket/hardware for my truck used, as well as the owners manual and a few other minor things.
Second off, the only way I can afford to do either kit right now is to fab it myself. I will be going the ebay route for all the cold side piping and fmic regardless. I had planned on buying a used P1SC to complete that kit. As far as the rearmount goes, I am pretty experienced with a mig, and have access to a lift, so welding up exhaust parts for the rearmount wont be an issue; I can do all of that myself. The only real thing I will need help with is the tuning.
My questions are:
1. Which one of these kits would you recommend for my application/needs? I am more worried as to how the power will come on different between the two; I often cruise at 85mph/2200-2400rpm on the highway back and fourth from school, so I don't want to be in boost at this level when doing this for 2 hours straight.
2. Also, which will perform best from a towing aspect? Remember, towing/offroad is prob 10% of overall use, or less; but I can't do without either.
My goals are to be over 400whp, and to run between a 13.5-12.5 1/4 time. Yes, I realize turbo has way more power potential, but the ProCharger will get me the numbers I want fine. Which setup would be more practical for my uses? I want the power on tap, to play and pass at will, but don't plan on ripping the truck daily because it has to last me. Thanks for all input
My questions are:
My two cents keeping in mind your "towing", is neither. I personally own a Procharger and don't have anything against them and love it. However, if possible, a twin screw or roots style is a better option for towing IMO. They add more grunt at lower RPM where as the centrifical blowers and turbos start making their power at higher RPM. Again, just my two cents.
Yeah, you can make almost anything work for you if you want it to. My thoughts are just something like a Magnuson is pretty basic and don't need to put too much thought into it and will meet all the needs you've shared.
My questions are:
My questions are:
Hunt&Fisherator
You just described a great application for a Maggie... I'm turbo'd and DD my truck but its in no way a "budget" setup, or one that I would tow often with.
Instead of trans mods. If you're looking for f/i and towing capability, go with a 4L80E right off the bat, you'll be happier in the long run and more than likely have less money in the swap than the several 60's you'll break along the way...
You're not going to be in boost at all with either unless you put the pedal down, if you are crusing with low load....
Can the stock engine tow? Yes obviously the radix/maggie has the low end torque, but the stock towing ability should be fine with a turbo or Procharger. The only caveat here is that with a turbo/Procharger you are going to want a higher-than-stock stall such as 3200+
Good luck sounds interesting! Don't forget about fuel and other necessary supporting mods.
-Mike
