Procharger vs Vortech
#21
can you explain your reasoning in detail? So what your saying is a big wipple would be much better than a P1 for drag racing? What about an F1R or even a D1 to be comparable?
#22
id say my P1 gets the job done just fine on my 5500+ pound truck and has already put a pretty bad hurting on someone running a radix with about the same amount of boost and almost identical mods to my truck. I was knocking down the door to 11s on a 95+ degree night at Crandall and with cooler weather I know it will be well into the high to mid 11s in the 1/4. I can only imagine what a D1 with a slightly larger cam and converter would net me. Call it a freak of nature but for a wimpy little P1 strapped to a 6.0, im very satisfied and glad that i did NOT go with a radix, tvs, whipple or anything of the sort. Procharger gets my vote, hands down! And on a side note, one of the radix trucks that i stuck it to has since swiched to a procharger.
#23
#24
I'm really surprise about what you say guys regarding the Procharger, The only centrifugal i used with a successful were a Paxton, and then the TVS2300.
It is all depends on what you like, if you wana buy a kit and spend extra cash to make it work good it is up to you.
#25
All I know is looking at my times compared to several maggie and tvs trucks with all the same or close mods, they havent had a chance. If you want to base the argument solely off of track times for which blower takes the cake, take a look at the top times for Silverado SS trucks over on the sss.com website. Currently I have the second fastest supercharger only (when i say only i mean no nitrous, etc.) on the site, only to be beaten by someone running a fully built 408 with a tvs2300 (11.71) which I plan to match or beat come fall/winter when we get some cooler weather. Im not trying to toot my own horn so to speak because I already know of a few builds currently going on that are going to come damn close to beating my times and im okay with that, but theyre ALL running prochargers.
#28
thanks for spending the time to write the long reply, I totally understand what you're saying and that makes sense completely, the reason for AWD is that there is 0 wheel spin.. and when cars have to deal with some at 20 or 40 roll i dont.. i thought the centri wasn't a bad idea is because i spend most of the time above 5k rpm, so i only go through low rpms when i launch it... check out the video.. the speedo is in kph, all motor , mods in my sig
I actually installed a P1 today on a buddies truck. It is by far the simplest kit Ive installed out of all the forms of FI. The only problem I really see with a properly setup procharger kit is top end boost. WHat I mean by that is the small size pulley you need to get boost coming in soon down low can take you right on past how far Id be comfortable with on a stock longblock. "right" and "comfortable" are all very subjective words obviously. Obviously yours is set up "right" but longevity wise? What do you shift at and how much is your max boost?
By the time its all said and done I may try one out if I keep my truck. I do love the whistle at idle
Krambo ran an 11.7 on his LQ9/radix combo. Never used nitrous to my knowledge. Trever ran an 11.7 also I believe on his 5.3/tvs1900 combo.
#30
I have no idea what krambos old times were which is why I said currently. I guess when he went all out on his new motor and nitrous and ran his 10.8 the old times were updated to only members currently running supercharger only and he was moved into the n20 category
