Procharger w/wastegate article in GMHTP
Mod with training wheels
Supercharged Cobalts have something like this from the factory. The ECM controls the internal bypass valve to provide more boost on the bottom and bleed off some boost at the top. One can assume those blowers are also 'working harder' but they are covered by a warranty for like 100,000 miles. Probably not making it work hard enough to cause damage within any kind of reasonable blower lifetime.
I was always curious if this would be plausible, guess i won the bet with myself/ seems a few on here are gonna be quick to jump on a little project here soon and try this out!
Baltimore Whore
They are using both. The bypass still stays open while driving normal.. It still closes under boost. The waste gate will allow the use of a smaller pulley to make more max boost while the gate will limit it to how much you actually want to run.. A smaller pulley will allow it to boost harder sooner, then open when you reach the set point..
Rick
thats pretty cool. Ive heard of guys using wastegates on blower setups for more bottom end, but hadnt heard how they were doing it.
So you could hook up a boost controller to the gate and set your boost per gear.
11 Second Truck Club
I just got around to reading this issue of GMHTP.
I know of a couple of local shops that have done this with great success on both a Camaro and a Mustang.
The shop in the article prefers to run the WG between head unit and FMIC...which is where I have my PC race by-pass...guess I would just relocate it post FMIC.
Thinking of going w/ SD tune...guess I could locate it where I have the MAF since I've already relocated the IAT sensor.
