Procharging and using the flex fuel pump
OK so I have been searching the site for a while but have not found a definite answer. Does anyone run the flex fuel pump with boost? If so, how much boost? I recently purchased a P1SC for my 08 5.3 flex fuel and am trying to gather all my fuel parts. The pulley I have is a 3.4" so i'm assuming around 9-10 psi? correct me if i'm wrong please. So will 44# injectors and the stock flex fuel pump hold up with that amount of boost? Help will be greatly appreciated!
I don't know much about flex fuel ,but in a stock 5.3 (IDK if yours is) , a P1 with a 3.4" pulley should give you 12# or more,I also think you should go with 60# injectors. My truck is not flex fuel and I'm still using the stock pump at 9-10# with a 3.6" pulley. I also have the cam in my Sig .
Well I already have the injectors so looks like the cost effective way to go is to just get a bigger pulley. I'm sure i'll still see a pretty good power gain with 8 psi still.
I may just set it all up and see how it acts during tuning. If I lose fuel pressure or the injectors are running too high of a duty cycle then i'll grab a bigger pulley.
