PT7685 GT42 Style on 5.3
Any thoughts or suggestions on this turbo for a 5.3?
PTE's PT7685 "GT42 Style" Turbocharger features the following:
• Exclusive CEAŽ (Competition Engineered Aerodynamics) compressor wheel machined from a 2618-aluminum forging
• Air-cooled, dual ceramic ball-bearing center housing rotating assembly (CHRA)
• Higher efficiency and faster transient response for maximum power and performance
• 76mm inducer compressor wheel
• “GT42 style” compressor cover with V-band discharge
• 85mm turbine wheel
• Turbine housing options:
- T4 Divided 1.12, or 1.28 A/R with 4 5/8” V-Band discharge
From what I understand Back Pressure is the #1 enemy of becoming more efficient on any given turbo setup. I was only considering the turbine size.. I'm sure the 4-5/8" V-band would considerably reduce Back Pressure on the PT7675 GT42 style.
Maybe the PT7685 GT42 style would be more appropriate on a 6.0 liter? ...And the PT7675 GT42 style on a 5.3?
PTE's PT7675 GT42 Style Turbocharger features the following:
• "GT42 style" compressor cover with V-band discharge
• 75mm, 84 trim turbine wheel
- T4 Divided .98, 1.12, or 1.28 A/R with 4 5/8" V-Band discharge
TimDave217
08-24-2015 04:38 PM
