Pulled the LSX yesterday......
#61
might have to move mine there as well.
do the ls2 style knock sensors use the same wiring ? could we just splice them into the gen3 to 4 conversion harness? or do the electronics work differenty? seems like it might be better to try a knock sensor that was designed to work in that spot vs the ls1 style .
There is an option in the tune to select either style sensor, but from what I read it is not clear that the LS1 PCMs have the necessary harware and software to handle the flat response sensors. Apparently in the LS1 PCMs there is a chip dedicated to processing the knock signals. The relevant tables in the tune would all differ as well. The PCM connector has to be re-pinned.
I see that Racetronix now sells an adapter harness for using the LS2 sensors (not the LS1 relocate harness). Haven't seen where anyone has done this though.
#67
LS1Tech Sponsor
You can not tell what the WOT fueling is from the end of the plug. You need to cut the threads off and look at the base of the porcelain after killing the engine after a WOT run. The one thing you can see is the oil speckles from detonation though.
MA$TER_E
09-09-2015 03:14 PM
