pulleyed down and just look what happened ...
Old 05-06-2012, 06:35 AM
scooter k's Avatar
+1 needs to be tig welded on.
Old 05-06-2012, 06:38 AM
11 sec. Truck Mod
TIM Z's Avatar
Mig or stick will be fine also bro
I used 7018 stick rod .
Old 05-06-2012, 08:02 AM
Gadgetized's Avatar
I'm with Tim, just throw some weld on there. It is hard to tell from the pic because the belt is beat up, but is the rest of the belt discolored on the flat side towards the engine? That pulley could have been walking off over time and you just didn't notice it. Did it mess up the hood or anything? Sorry to hear about this.
Old 05-06-2012, 09:54 AM
sprayedenali's Avatar
Yup, just weld it....
Old 05-06-2012, 10:16 AM
SCREAMINXL's Avatar
I had to weld mine too. That was with a side mount maggie. I was under the hood and noticed the belt tracking differently on the water pump. Checked the pulley and found it had walked off 1/4 inch. Did some searching on PT and found out that it does happen. Tapped it back on and fired up the miller-o-matic!
P.S. Last time my friend broke a 6 rib it took the 4 rib A/C belt too. He couldn’t keep an A/C belt on to save his life. The broken belt must have hyper extended the tensioner. Replace the A/C tensioner and all is well.
Old 05-06-2012, 10:40 AM
idahoblkss's Avatar
I just put the belt on a hour b4 this happened it was brand new lol hopfully it still ok. Its good to hear that people have had this issue and its been resolved. 14 psi in first felt strong most ive seen in first is 12 so im guessing i would of seen around 17 at the top of second if i would of made it and the most ive seen b4 is 14 in second.
Old 05-06-2012, 04:01 PM
charcold-bowtie's Avatar
Superado did that years ago. Maybe just something that is a hair more common with the PC guys.
Isnt the belt visibly ripped right there? Or am I lost lol
Old 05-06-2012, 04:08 PM
Baltimore Whore
Mangled03gmc's Avatar
This has happened before. The water pump pulley needs to be welded to the shaft. I need to stop dicking around and put a electric pump on so I don't have that issue
Old 05-06-2012, 04:09 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Yeah the belt looks toast to me
Old 05-06-2012, 04:10 PM
2004SSS's Avatar
might want a bit more slack on the belt as well if its too tight , the weakest link will find its way .
Quick Reply: pulleyed down and just look what happened ...
