pulleyed down and just look what happened ...
I'm with Tim, just throw some weld on there. It is hard to tell from the pic because the belt is beat up, but is the rest of the belt discolored on the flat side towards the engine? That pulley could have been walking off over time and you just didn't notice it. Did it mess up the hood or anything? Sorry to hear about this.
I had to weld mine too. That was with a side mount maggie. I was under the hood and noticed the belt tracking differently on the water pump. Checked the pulley and found it had walked off 1/4 inch. Did some searching on PT and found out that it does happen. Tapped it back on and fired up the miller-o-matic!
P.S. Last time my friend broke a 6 rib it took the 4 rib A/C belt too. He couldn’t keep an A/C belt on to save his life. The broken belt must have hyper extended the tensioner. Replace the A/C tensioner and all is well.
I just put the belt on a hour b4 this happened it was brand new lol hopfully it still ok. Its good to hear that people have had this issue and its been resolved. 14 psi in first felt strong most ive seen in first is 12 so im guessing i would of seen around 17 at the top of second if i would of made it and the most ive seen b4 is 14 in second.
Baltimore Whore
This has happened before. The water pump pulley needs to be welded to the shaft. I need to stop dicking around and put a electric pump on so I don't have that issue
