Question about front mount turbo kits!
I like my Trick kit. Complete for sure. I would not use silicone or rtv or whatever. It will not hold. Metal gaskits ftw. Also use a straight through diesel muffler system. It can be made to go right to the down pipe and have no backpressure.
Its what I have and it sounds good and flows better.
http://www.youtube.com/watch?v=rdKZc6YUEdE
Banned
He gave me the flex joint to install if I wanted, if I don't find a way too mate the two surfaces I might end up having the correct flange tigged on the manifold I wish I knew what all you guys used for a gasket on your front mount because most front mounts seem very similar!
Banned
I have tendancy too worry about stuff and I have used the copper rtv silicone on just headers without good success, I do want to make big power but keep drivability the permatex is rated up to 700 degrees and I think turbo temps can get up to 1600 degrees.
Unless I'm not seeing it right, that gasket fits the turbo flange and everything bolts up! Just use it! That little bit of blockage doesn't matter! At all! Not worth your time to put a new flange on! !!!
5.3lSilverado
25
08-29-2016 12:48 AM
