Questions on race fuel...
Im heading to the dyno this Saturday and Id like to run some race fuel in the tank to be on the safe side and get some more timing out of her. I cant find any unleaded fuel over 100 octane, I can get 110 leaded all day long but thats a no no with the wideband and my other o2 sensors right? I can get 100 octane right out of the pump at a few gas stations so should I just run straight 100 octane in the tank? I was going to put 5-8 gallons of 110 and the rest 93. I didnt know if anyone had any experience with doing something like this. I have a meth kit I will be installing this winter so I would just be doing this for the one time.
2nd fastest 5.3 ECSB
IIRC you can find 103 octane unleaded in 5 gallon cans but I believe that's the highest you can find. I don't think leaded will hurt the O2's (could be wrong) but it will screw up a CAT fast.
I always drive to the pump and add 5 gallons of 100 proof to bring my tank to 1/4 so it's a mix plus I run meth.
I take it you will be tuning at the track to take advantage of the higher octane?
Fine with 110 leaded? Thats all I can find around here, other than 100 unleaded.
Well I had read that it mess's up the wideband or I should say decreases the life of the narrow and windband o2s. Also a guy at the race shop said it would be a bad idea to mix leaded fuel and unleaded.
I am going to a dyno in mass so I am making a little trip out of it. I will be going to my parents house in RI so along the way I was going to scan and send the logs to Wheatley for him to look over. I was going to scan on the dyno and send them to Charlie for him to look over and update the tune to utilize my time with the dyno.
Anyone see a bad thing with running straight 100 octane other than the cost factor?
Mod with training wheels
It is really just my opinion, but I wouldn't dyno on conditions that I can't reproduce anywhere else, either at the track or street. I take comfort in knowing that the numbers I dropped on a dyno are the same numbers I'll see and feel if I stomp on it regardless of time or location.
If you dyno with a shitload of timing but have to pull it all back once you top it off with 93 on the street, your grin factor won't be so high anymore
i had a 100 LL aviation fuel tank cleaned a couple years ago.the cleaner they used dyed the fuel when it was refilled.which is a FAA violation cuz the color is wrong.so we used in to get to the track and other employee vehicles. and wheatley stated correctly..it definately screwed up the cats.
I would stay away from the l eaded... it will foul the wideband sensor. I would just run what you are going to use all the time, that way you can tune for the fuel you are using. Hate to see a tune with 100 then fill her up with 93 and torch a piston.
