quick question on cr
Old 06-22-2010, 09:42 PM
droppedchev's Avatar
Default quick question on cr
im running a lq4 with stock gaskets and 243s idk what the cr is i think its like 10.5 would it be to much to run boost or should i switch back to the 317s what do u guys think
also im running the cam in my sig 228/228 588 588 could i still run that or would i have to swap that to a ls6 cam
Old 06-23-2010, 11:48 AM
YenkoST's Avatar
LQ4 is 9.5:1 compression and the 317s are 72 cc heads. 243s are 64.45cc heads so you are roughly in the 10.25:1 compression area. Depending on how much boost you want to run. You should be fine with 8-10 psi with an intercooler on that compression. LS2 TBSS guys are running 6 psi intercooled with 11:1 compression. It also has to do with the amount of timing you run as well.
Old 06-23-2010, 02:52 PM
scooter k's Avatar
I set mine up to run 10.5cr and run 16psi with no troubles. The higher CR makes it run alot better out of the boost too.
Old 06-23-2010, 04:49 PM
YenkoST's Avatar
Just curious, are running alky/meth and whats your timing looking like at WOT?
Old 06-23-2010, 06:22 PM
I have a gauge for that
Atomic's Avatar
Old 06-23-2010, 06:43 PM
deff glad i can run those heads another question is should i swap my cam out its a 228/228 588 588 112lsa
Old 06-23-2010, 07:26 PM
old motorhead's Avatar
I ran that same setup for quite a while on about 9psi with an occasional 75 shot of n2o. It ran lean a few times and I'm building a forged motor now. I'm going to look into a little more capable fuel system on the new motor.
Your cam isn't the first one that I would choose for boost. You can do better there.
Old 06-23-2010, 07:29 PM
YenkoST's Avatar
Depends on what FI you are going with...procharger or TVS.....there are better options....turbo....probably would be ok but I would get a custom grind so it will be exactly what you want.
Old 06-23-2010, 08:24 PM
im going with a front mount turbo and its only for now
Justin87gn
09-10-2015 12:06 PM
custm2500
09-08-2015 05:53 PM
bisqikss
09-08-2015 03:35 AM
SWINGRRRR
09-03-2015 07:49 PM
mr03silverado
09-02-2015 11:43 PM
Quick Reply: quick question on cr
