racetronix drop in fuel pump module for 99-03 trucks
Import Moderator
I might be buying one of these shortly... I put a 255 in about 2 months ago and the damn sending unit is going on me Probably just drop one of these in and be done with it
Slowest turbo build ever!
I bought one of these but did not see anywhere that said I needed to buy anything else to make it plug and play.
Like said though either call racetronix with your VIN# or your local chevy dealer and see what ACDelco part# your pump is.
And I dont see a need for any wire kit, these modules have all the factory connections right at the top of the bucket. But I have NOT installed mine yet so Im not sure.
The wiring is a "hot wire" kit that runs a full 10ga wire from the alt to the pump, using the stock wire harness as a trigger and a relay so it has a good, solid power source to the pump.
Just email them with what you got and what you want they will set you up with what you need. They had me change out my wire bulk head on to of the bucket for the 4 flat style because it has bigger conductors in it then the 4 square for less current loss, then set me up with the right Hot Wire kit to adapt my stock wiring to work with the new bulk head . Really great company to work with!
