Radix 2 bar MAP sensor
Does anyone know where I can pick up a 2 bar map that is the style the radix uses? I am curious if some of the factory boosted 3.8 v6 motors came with the 2 bar? Anyone have a clue?
Radix doesn't come with a 2bar MAP sensor.To add a 2bar MAP sensor you need to add programming to allow your PCM to read to 2 bar signal.A 2bar MAP from a supercharged 3.8 will work with the programming HPtuners sells.Don't use the MAP from a turbo TransAm it's a 3bar.
I believe the GM PN is 12580698 works with just a slight modification. It's for the Supercharged 04 Saturn Ion Red Line. That's what they tell me anyway. I will know for sure when the one I ordered get here and I put it on my truck.
You can try Summitracing part#ACC-74776.You'll need to make an adapter plug.I made one using a late model Ford voltage regulator the prongs were a match to the truck MAP I cut the regulator's plug away with Dremel tool and soldered the wires of a MAF replacement harness to the rear of the prongs.
Originally Posted by zippy
i can get you the part number for the recomended one to use.
http://www.partsamerica.com/ProductD...tnumber=FE1636
That is a 2.5bar with a built in BARO it won't work.Save your money.
