Radix 2 bar MAP sensor
Old 09-29-2005, 07:10 PM
I have not tried the the Saturn MAP,I did try a Turbo TransAm Map that did not work.Please post your results with the Saturn MAP sensor.I was passing on information that was given to me a few months ago.The Saturn is identical in appearance to a stock truck MAP a straight swap would be great.Having to make an adaptor is a real pain.
Old 10-04-2005, 09:04 PM
Vdrumright's Avatar
Originally Posted by hellbents10
I get mine through Zippy, he has the part number for the one thats a direct replacement for the style thats on there.
Why haven't we done this conversion on my SS TJ?
Old 10-05-2005, 04:36 AM
BigBlackAv's Avatar
what is the purpose of this mod?
Old 10-05-2005, 06:00 AM
It allows your PCM to recognize boost conditions by expanding the MAP ramge to 2bars.A 1bar just reads vacuum to 0,while the 2bar reads vacuum and boost to 14.7lbs.If you are using Speed density tuning it is nessasary with a forced induction to tune VE in the boosted regions.
Old 10-08-2005, 12:50 AM
DrX
DrX's Avatar
Originally Posted by kbracing96
Really? I found 6+ threads on EFILives forum that said that pn 12580698 was a plug and play 2 bar map sensor for a LSx motor. A couple of the post are from guys that are currently using it. I hope it the right one, I just ordered one from gmpartsdirect yesterday. Jesse from Wait4me told me a supercharged 04 Saturn Ion MAP was a pulg and play for this, other then changing the seting in the pcm. Can you confirm its not he right part I need?
Let me know if this is the correct plug n play sensor to fit the manifold. GM Parts Direct says its for supercharged Buicks. I want to install EFI Live's custom 2/3 bar OS.
Old 10-08-2005, 11:23 AM
kbracing96's Avatar
I will Should have it some time next week.
Old 10-08-2005, 05:22 PM
LS1Tech Sponsor
hellbents10's Avatar
Yes Vince we should be doing it to yours too. Makes a whole world of difference at part and full throttle.
BTW the 2 bar that I use is from a 2005 supercharged Impalla SS. Looks identical to the stock 3 wire map sensor.
Old 10-08-2005, 05:51 PM
greentahoe's Avatar
So do we know if there is a plug and play 2 bar MAP for our trucks? If so, who has the part number??
Old 10-08-2005, 07:04 PM
Running a 2bar MAP sensor requires 2bar PCM tuning.I'm running 2bar tuning from HPtuners using a 2bar MAP sensor from a supercharged buick for which I had to make a adapter wiring plug,leave the stock MAP in place to seal the opening in the intake manifold and run a vacuum line to the new MAP sensor.That's not plug and play.Kbracing96 had heard that the MAP sensor from a supercharged Saturn would plug into our intake manifold and work with the required 2bar tuning,thus eliminating the extra plumbing.Maybe he can post the results of trying the Saturn MAP.I really would like to have a MAP that plugs into our intake and matches the 3wire plug.
Old 10-08-2005, 08:06 PM
greentahoe's Avatar
I see, thank you. Is the extra capability to tune using the 2 bar MAP sensor something that you have to send your cable back in for like the EIO??
Quick Reply: Radix 2 bar MAP sensor
