Radix and 408 low fuel pressure help
Old 02-14-2013, 01:09 PM
Q8 6.0's Avatar
Thanks for the info i will look for it when i open that fuse box so signal wire to that heavy gray live to battery positive black to earth sounds easy i think will find out when i do it
Thank you
Old 02-24-2013, 10:16 PM
Q8 6.0's Avatar
Can anyone tell from this picture which is wire for fuel pump PLEASE
I have magnavolt instructions not clear for 2005 pickup
These two harnes connectors are under the fuse block engine compartment near brake
Old 02-25-2013, 07:51 AM
Gadgetized's Avatar
It is a gray wire. It will obviously be directly under the fuel pump relay. Find the gray wire under the relay, and poke it with a test light. It will remain lit when it is running, and light for about 5 seconds with the key on and it is not running.
Old 02-25-2013, 09:16 AM
TX Tahoe Z71's Avatar
+1, that's how I found mine
Old 02-25-2013, 05:12 PM
Q8 6.0's Avatar
Yes I found it under fuel fuse relay thanks..everything was very easy install except the white wire I had to remove dash gauges to find rpm wire...
I am going to dyno for retune hope it will supply enough fuel
Thanks a lot for your help
wrb002
08-31-2015 12:00 PM
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: Radix and 408 low fuel pressure help
