Radix and 408 low fuel pressure help
Thanks for the info i will look for it when i open that fuse box so signal wire to that heavy gray live to battery positive black to earth sounds easy i think will find out when i do it
Thank you
Thank you
Can anyone tell from this picture which is wire for fuel pump PLEASE
I have magnavolt instructions not clear for 2005 pickup
These two harnes connectors are under the fuse block engine compartment near brake
Yes I found it under fuel fuse relay thanks..everything was very easy install except the white wire I had to remove dash gauges to find rpm wire...
I am going to dyno for retune hope it will supply enough fuel
Thanks a lot for your help
noproblems209
08-10-2015 06:57 PM
05GMC4.8
08-07-2015 09:55 PM
GMCtrk
07-17-2015 06:39 PM
Mossyoakglock
07-17-2015 08:30 AM
