Radix coolant tank?
Old 01-26-2011 | 09:09 PM
TrickTurbo's Avatar
Truck Sponsor
Yes I do. It cost 225.00 + freight.
The aluminum tanks are something we have done for years with great success. Just have not put them up on the store yet.
Old 01-26-2011 | 09:55 PM
03sierraslt's Avatar
Mine works good, then again its the only way I have run mine is with the Larger Trick tank.
Old 01-27-2011 | 05:44 AM
TIM Z's Avatar
11 sec. Truck Mod
Here is the one that I am running, I believe this is one of Tricks. Cant remember at the moment.
That tank looks great Pat, i like the fact you can fit a frozen bottle of water in it too if needed.
The new coolant tank looks perfect too.
Old 01-27-2011 | 06:38 AM
JimS's Avatar
Gotta love the size and I like the aluminum... but I also like the plastic... which I'd paint white.
Old 01-27-2011 | 05:11 PM
TIM Z's Avatar
11 sec. Truck Mod
You also have a clean , great looking engine bay Jim !
Old 01-27-2011 | 09:14 PM
JimS's Avatar
Thanks!!
Old 01-28-2011 | 12:49 AM
1bad2k's Avatar
What about the issue of heat. That aluminum tank looks awesome but would it shed a noticeable amount less heat than the plastic one?
Old 01-28-2011 | 05:15 AM
I follow what you are saying but I have yet to even find the tank to be warm.
Old 01-28-2011 | 09:05 AM
1bad2k's Avatar
Awesome, must not be an issue. Looks like I know which tank I'll be using
Old 01-28-2011 | 09:15 AM
TrickTurbo's Avatar
Truck Sponsor
Aluminum will absorb heat from the engine compartment. How hot it gets really depends on many factors.
Heat outside, HX ability to remove heat, boost levels how long in boost, and run time. Long drives in Texas in the summer, your engine bay will be hotter then short drives.
Not saying it absorbs a so much and that's why we built the composite tanks. Composite are more cost effective and more versitle.
Aluminum can have more bling, and more cost effective to build one offs.
