Radix is on, Here I go thinkin Part II
Old 08-27-2012 | 09:02 PM
  #51
03sierraslt's Avatar
My lawd, you got any tire smoking vids yet. This is taking longer then revolution did..
Old 08-27-2012 | 09:04 PM
  #52
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by fastnblu
Just thought I'd point this out. Please see original post on this thread, what, wasn't it like 8-13, then had powdercoated fittings done, I drove on it, tore it down, fixed a serious issue, & moved on to my next phase. All inside of 2 wks.
Careful who u doubt.
2025 huh? Wow that came up fast.
https://www.performancetrucks.net/fo...-505583/page7/
I'm not sure how you tell time Tom, but I know your damn slow at blower installs . Haha
I am also going to have your smilie privileges taken away as you abuse them Wayyyy too much
Ok waiting for the 10 page reply .........
Old 08-28-2012 | 10:44 PM
  #53
fastnblu's Avatar
Slow how? Cause I built my trans 1st, before a blower blew it up? Since a stock 60E is borderline to start? And I already want more boost.
Or cause I decided it'd be wiser to do all my supporting mods so I didn't have a blower in the way, or anything it ties to?
Or cause I had to save up til I could afford the trans after the Radix purchase while workin a part time job?
And that I hafta use someone else's garage while I do it on my vacation so my life doesn't get further complicated?
Or cause I ran into problems during my install that good people helped me out either thru text, phone or in person?
Perhaps my lack of experience in havin never done a S/C didn't help. But then again some of the other stufff on this truck I never did before. That's why it's called experience.
I may not have the fastest or best lookin, but my budget dictates & when they are there, my time constraints, can be overwhelming. I put my heart & soul into everything I do. I have a lot of respect for Roger, Jarrod, & Pat among others.
So no 10 pg. whatever, wherever that came from. My threads when I can, I try to help others thru pic & words, so they don't hafta make same mistakes I did.
No smilies either.
If someone wants to be a keyboard warrior, that's fine. I will help just about anyone, if I possess the knowhow. If I'm unsure, I'll say I think this ... or that. When I'm wrong, I can admit.
Hopefully my response is acceptable. If it's not, I can do another but it may lack the eloquence. No spit & polish.
Old 08-28-2012 | 11:25 PM
  #54
TX Tahoe Z71's Avatar
I think Tim was just giving you a hard time.
I like that Trick tank. Where is the pump mounted? My problem is that I have my inlet and outlet on the h/e on the driver's side, so the hoses would be routed back across the hot engine bay if I went with this. But it looks sexy so might be worth it.
Old 08-28-2012 | 11:34 PM
  #55
AKlowriderZ71's Avatar
11 Second Hall Moniter
Just re-mount the HX with the nipples on the passenger's side. That's how mine is, just took about 10 minutes to make it happen.
Old 08-29-2012 | 12:48 AM
  #56
nonnieselman's Avatar
Dont pay attn to Tim. He lost a few screws in his rocker.
I gotta make me a water box, i have mine in a loop right now with one them heater hose flush kits with a 'T' in it so i could fill it.
I think it held about a gallon.
Time to break out the stainless and TIG!!
(typo....)
Old 08-29-2012 | 09:56 AM
  #57
that could work (but I would likely have to pull the bumper off too, mine is the big CTS-V one)
/thread hijack
Old 08-29-2012 | 10:18 PM
  #58
fastnblu's Avatar
Perhaps he was. Movin on to more important things.
That's no problem on HX I & O comin off Driver's side, mine do too. I thought I posted a pic, but maybe that's in Part 1. If u need it, just ask me.
I never moved pump. Just took it off old 1 QT reservoir bottle, & just visualize, it's folded or flipped hose over to pass. side. Snake it around back there til u like how it looks (u may lose a few drops, but pinch off pliers minimize that). It's easy TX. No extra cuts, no excess either.
But the other hose needs to be longer likely. Luckily I had extra left over from Maggie, & extra in my reserve hose parts stock. The bigger hose that goes to pump was from my parts stock. Ya, I know, not everyone has hose left from previous projects. But an adapter between 2 diff. sizes is needed.
Not needed on mine.
...that could work (but I would likely have to pull the bumper off too, mine is the big CTS-V one)
/thread hijack
U should probably gimme your CTS-V then & u use my stock Radix HX.
5.3Caprice
11-07-2015 09:56 PM
Fast86z
08-23-2015 01:35 AM
Blackrat48
08-16-2015 12:56 PM
therock
07-25-2015 10:23 AM
sTNT971
07-16-2015 01:39 PM
Quick Reply: Radix is on, Here I go thinkin Part II
