Radix + Nitrous..outcome?
Old 07-22-2009, 04:09 PM
cccharged's Avatar
Default Radix + Nitrous..outcome?
Going to put my truck on the dyno this weekend..its a 4.8 with radix with all the bolt-ons and tune and T-56...we have thrown around the idea of hitting it with a small 30 or 40 shot mainly to try to keep the IAT down some and of course a few more HP#'s...question i have is can i put the nozzle in the air filter and spray over the MAF? will it detect there is more coming through and send in fuel to accomidate the nitrous? Or should i put the nozzle in the intake tube and let my tuner accomadate for the fuel?
Old 07-22-2009, 04:26 PM
13 Second Truck Club
A Low Dime's Avatar
If you have enough injector to cover the extra fuel needed.
Old 07-22-2009, 04:29 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
don't do it, it'll never work and you'll only blow your motor!!
search my friend, search. Nitrous will not cool the charge, doesn't for me or anyone else that I know. It will boost torque like a muthafugger! 35 shot to start, feed it more as your tuning will allow, hold on and pray.
Old 07-22-2009, 04:55 PM
I have a gauge for that
Atomic's Avatar
Spray through the filter? Never heard that....sounds like a bad idea to me.
Old 07-22-2009, 04:57 PM
A Low Dime's Avatar
He means mount it in the top of the filter, the hard part
Old 07-22-2009, 05:01 PM
Atomic's Avatar
Oh ok, duh, that makes much more sense.
Old 07-22-2009, 05:30 PM
no title here
skyhighsami's Avatar
Nah, ZEX I think makes a kit on the end where on a cone filter it says KN that they put a nozzle. They spray across the MAF and let it richen the intake. Again, only if you have enough injector to support X amount of boost and the adding N2O
Old 07-22-2009, 05:31 PM
cccharged's Avatar
Injector's should handle it...should i spray before or after the maf?
Old 07-22-2009, 05:33 PM
trever1t's Avatar
Dry sprays before and wet sprays after the MAF
Old 07-22-2009, 05:36 PM
Atomic's Avatar
Which is wet systems usually have 2 solenoids, 1 for nitrous, the other for the extra fuel you will need.
Quick Reply: Radix + Nitrous..outcome?
