Radix Is this normal
Old 05-31-2006, 03:04 PM
High on diesel fumes
thunder550's Avatar
Blower whine is sweet! It's normal, and you will learn to love it!
Old 05-31-2006, 03:30 PM
krambo's Avatar
Originally Posted by Allgonoshow
you can't hear the blower over the exhaust or exhaust over the blower,
mine i can't hear much over the blower.
I'm not saying it's a bad thing I just want to be sure it's normal.
i expected some noise at wot but not at light load.
what have to got for exhaust.
Can't hear the blower over the exhaust. I even have a 1/4 mile run taped and I can hear the whine a little but nothing like a cobra or a lightning going down the track.
Old 05-31-2006, 03:34 PM
Allgonoshow's Avatar
what exhaust setup?
Old 05-31-2006, 04:15 PM
krambo's Avatar
ASM headders, hollow cats, X pipe, dual magnaflows, exit before pass rear tire.
Old 05-31-2006, 04:33 PM
Nick™'s Avatar
I've never heard a Radix powered truck, but I've heard a C5 vette with one, it was quite obvious what he had under the hood
Old 06-01-2006, 03:07 PM
spoke to m7 rocket today and his new one is doing the exact same as mine so I quess
it's normal.
Cool, the thing works great so i'll learn to like it.
Old 06-02-2006, 12:03 AM
THAT GUY's Avatar
You will hear the blower a LOT more with an open air element that you will with a closed air box. I've seen a couple of people do some really trick ducting to the stock air box with some 3" reinforce hose and scoops in place of the fog lights. It worked so well that you could watch the boost go up as the speed went up. It also pulled in a lot cooler air than an open element under the hood does.
Old 06-02-2006, 06:37 AM
that's interesting, you suggest I put the oe air box and k/n filter on and try that, i'll put the foam in the fender well also.
It seems like the noise is more mechanical noise from the blower than the air intake but this may help.
Old 06-02-2006, 09:15 AM
unklej's Avatar
allgonoshow, I sent you a pm
Old 06-02-2006, 10:30 AM
THAT GUY's Avatar
The stock air box will cut the noise down, but unless you do some type of ram air into the box you be making more power with the open element. I was just throwing out an alternative if you get tired of the sound. Most guys I know like the sound, and it sounds like you don't mind it........it's the spouces they have to quiet it down for! I never did directly answer the original question about the noise being normal though. I would say from what you are describing it is a normal sound.
Quick Reply: Radix Is this normal
