radix ppl come in
Old 06-19-2009, 01:32 PM
Most Hated's Avatar
Default radix ppl come in
what gears and tire size are u all curently runnin im runnin 4.10's and some 315/35/17 do u all think i should go with 3.73's
Old 06-19-2009, 01:42 PM
BlownHD's Avatar
Ive got 4.10s with 285/75r16, I'm happy with the setup, but I have a 5spd.
What gears you should run all depend on what your trying to do with the truck.
Old 06-19-2009, 01:47 PM
Most Hated's Avatar
i heard the radix dose not like that much to be in the high rpms, cuz right now it seems like if im running 4.56 with the gears and tires so what i wanted to know if i go to 3.73's is it worth it , right now my 3rd gear ends like around 12xmph in 3rd
Old 06-19-2009, 02:03 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
I have 3.73, but would rather have 4.10
Old 06-19-2009, 02:07 PM
11 Second Truck Club
Breeze's Avatar
Haha I have 4.10s and wish I had 3.73s
Old 06-19-2009, 02:13 PM
Most Hated's Avatar
its depends on the tire size in my case i think 3.73 would be better so wat do yall think
Old 06-19-2009, 03:26 PM
ForcedTQ's Avatar
Lightbulb
According to my calculations you have a 25.68" tire/wheel combo, that is pretty damn small for these trucks. Are you having issues getting it to hook out of the hole? Seems that you could increase gas mileage and have a more tractable power-train if you step down in your gears. That is unless you are right at the top of third when you hit the end of the quarter, which is right where you want to be; as long as power hasn't started dropping off yet, so that you don't have to shift into forth. Going with a lower rear end ratio will lower your RPMS at cruise and at the end of the quarter. Your call, but like I said before, small tire diameter.
Old 06-19-2009, 04:13 PM
Most Hated's Avatar
i think the power band ends too quick that's y im thinking bout stepping down but as soon as i get my truck working right ill see how it works with 4.10s
Old 06-19-2009, 06:36 PM
SuperchargedSS's Avatar
4.10s with a 285/40/22 in back tho
Old 06-20-2009, 12:46 PM
thunderwagen's Avatar
I think you should bring it down with that small of a tire. I went from 3.73 to 4.10 after I did the 80E, but im also running 32" tall tires.
Quick Reply: radix ppl come in
