Radix w/ 2 Bar MAP Sensor Tuning
#51
Moderately Differentiated
I haven't read this whole thread, changes topic on me too much (bad case of ADD here) LOL, but turboberserker gives a great explanation about it all. Granted he is trying to sell the mafless (SD) idea, hence the thread topic.
https://www.performancetrucks.net/fo...d.php?t=367876
I have the radix, 2bar, and have been ve tuning off and on for a few days now. Awesome resolution, it is plainly obvious to me how much more control I have over fueling. Some will say you could just do it with the maf though...no way, 2 bar ve and what map you are in is awesome.
0260IN3, in your above post about psi,I believe you are confusing psi and boost if I am reading your post correctly.
#52
PSI=BOOST Same thing in my books. Sorry if it sounds confusing as I blabber on.
#53
Sorry about that.
D
#54
blownerator
Personally I would leave your truck alone....I mean you use it for towing right? Why would you need the 2 bar map sensor and the calibration to go with it. The MAF is more than capeable of keeping up with 95% of the trucks on this site. I have seen ALOT of HP made on a stock MAF before it becomes an issue.
If I were you, I would leave it alone and tow tow tow away your days!
#55
Additionally I am quite excited to have a speed shop into tuning so close to where I live so am anxious to start working with Mark and Nolan on my vehicles.
D
#56
blownerator
Originally Posted by Blowndenalixl
I am curious to see if I can get a bit better mileage both towing and non-towing. Any any extra performance will be a bonus too (although I may be maxed out already.
D
D
I understand your excitement finding a tuner shop so close to home! Its always nice to have that available.
I just dont see how one could tune better then the MAF is going to respond. You could probably get the same power with a dyno tune,and save yourself the expense/headache of the 2bar.
Again, Just my .02.
Blown364 is running deep in the 11's on the stock MAF, and I have a feeling be may be the first Radix truck in the 10's soon.
#58
Again, Just my .02.
Again, Just my .02.
The 2 bar tune is not about the power, and that has been said several times in this thread.
The 2 bar tune is about the resolution in the tune. There is no doubt the MAF can make good power, but it can't be tuned as finite as the 2 bar can be. The 2 bar sees all the different boost levels not just grams/sec of air flow, that can be maxed out with enough air flow from a blown or turbo application.
I belive for Blowndenalixl it's about milage and better tune under towing conditions, not max power.
#59
