Ran truck for first time at track.. Disapointed!
#41
I will go to napa and order some BR7EFs, no one here has those in stock.
My boost/vac gauge and BOV are referenced through the Intake manifold nipple.
My valve springs are Yellow LS6, not the stock ones.
Im going to give it some last trys with justin, hope we can get it right, he seems to think it might be that my maf is being fooled (SEE PICTURES)
He says my maf is reading about 19 psi of boost.. but im only doing about 13, so its putting in way more gas and pulling timing. He told me to rotate my MAF 90º and see if that changes anything...
P.S. My MAF was pushed off the housing while doing a highway pull, so i put that huge zip tie around it to prevent it from happening again
#42
ok well it seems like will go with an SD tune.. will a 2 bar map be fine?
i do plan on swapping my valvesprings, but in a little while.. i want to swap my 80e first
#44
i would get some kind of vacuum back on the heads.. my 5.3 didn't come with the egr we put and aftermarket one on their to get ring seal. saw 10hp at the wheels difference because of it
#45
I was MAF and had all kinds of problems but mine is tucked in my 68 pickup. I am working on the SD tune right now and it sure makes a world of difference in mine. Again my cold piping had some bends in it around the MAF causing it to freak out. Alot of people still run teh MAF with the turbo.
#46
Im still on MAF and is running great...its a bummer u dont have a good local tuner. Id have to agree with the majority here. U should learn to tune and that way ull have it dialed like U want it WHEN u want it.
#47
You're on MAF at 20psi and 790rwhp? Aftermarket I assume? Draw through or blow through?
#50
If possible i would like to stay on MAF, correct me if im wrong but some people have told me tune would be a little finer, and truck would have better idle, cold starts, etc. But right now, im just tired of my truck being this slow.
i would love to learn, but that involves another 700+ dlls for equipment, 3 weeks to get it over here, and then.. start learning
GMCtrk
07-17-2015 06:39 PM
