Re-arranged my throttle bodies.......
Old 05-06-2010, 11:31 AM
  #41
TURBHOE's Avatar
this may sound like a dumb idea. but what if you put a set of bov's on the manifold. that way when you let out the blower don't slow down so fast. kinda like on a turbo where it keeps the blades from stopping suddenly. all that extra air could escape.
Old 05-06-2010, 03:26 PM
  #42
DrX
DrX's Avatar
Originally Posted by Spoolin
Wow, that's a bit close for comfort especially since there's still a little bit left travel left in that tensioner. That might be why your shredding belts too right? Where you go from here, what pulley you gonna move?
In this vid the tensioner is clocked a little closer to the idler than it was before. I don't think there was belt interference before, the pulley alignment was definitely off. Running out of room to move things around. Not sure if a single tensioner can take up all the slack........maybe if there was a lot of wrap on it.
Old 05-06-2010, 03:28 PM
  #43
DrX
DrX's Avatar
Originally Posted by TurboGibbs
Cool video. That explains a lot. Damn that belt stretches! For a quick fix you could put a stop bolt into the idler bracket to stop the tensioner right before it contacts the idler. Put then it may unload the belt and cause some slip at high boost.
Could you clock the tension back (CCW) so that the minimum stop is more to the passenger side and a shorter belt?
Less tensioner travel available that way.
Old 05-06-2010, 03:44 PM
  #44
DrX
DrX's Avatar
Originally Posted by OnyxSilveradoSS
how hard was it to use dual TB's?? I have been thinking dual 78's would be better than a single 100mm...is there a special adapter??
Had to build a controller.
Old 05-06-2010, 03:52 PM
  #45
12 Second Club
fastlt1's Avatar
I was hoping you would left both on top and put one of these on it.
Old 05-06-2010, 04:38 PM
  #46
DrX
DrX's Avatar
I don't think that would pass on the street.
Old 05-06-2010, 09:26 PM
  #47
MikeGyver's Avatar
Since no one is responding: That would only work if the blowers were driven by a one-way clutch, so that they could freewheel on coasting. What happens now is that it is the engine that is slowing the blowers so fast through the belt, not the air.
Old 05-07-2010, 06:16 AM
  #48
GFYS and STFU
Spoolin's Avatar
Is it in this thread that someone posted a link for a ratchet type pulley? (forgot what they are really called)
Old 05-07-2010, 06:57 AM
  #49
TURBHOE's Avatar
thanks for responding,
see i thought it was the blowers that were trying to slow the engine due to air pressure build up inside the manifold. i can't watch damn videos at work (streetfire.net only). when i got home i got to watch the vids and could see the belt doing its thing.
Old 05-07-2010, 08:41 AM
  #50
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Maybe use some ati super pulleys?
Quick Reply: Re-arranged my throttle bodies.......
