Re-arranged my throttle bodies.......
Old 05-07-2010, 10:47 AM
  #51
DrX
DrX's Avatar
Originally Posted by TURBHOE
thanks for responding,
see i thought it was the blowers that were trying to slow the engine due to air pressure build up inside the manifold. i can't watch damn videos at work (streetfire.net only). when i got home i got to watch the vids and could see the belt doing its thing.
The bypass valves in the blowers also open up as soon as the TBs close down (i.e. when there is vacuum behind them).
From the vid it appears that the belt is pretty stable now when the throttles slam shut. It is just the stretch that I am concerned about.
Will the belt stretch more under boost, when each blower requires 100hp of drive power? How much stretch can the belt tolerate? Then again, looking at some papers on belt dynamics, it looks like slip will likely occur in this system and limit stretch anyway. What happens when you go to a wider belt?
Didn't know that they used these OAD pulleys on the Vettes:
http://www.youtube.com/watch?v=4EXYP...eature=related
http://www.decouplerpulley.com/lookup.cfm?action=search
Old 05-07-2010, 11:23 AM
  #52
TURBHOE's Avatar
maybe this has been mentioned, but what if you off set the blowers (or the pulleys). get a custom crank pulley made and have each blower have its own belt. that way there is less stress on just the one belt. hell then if you wanted you could cog the blowers and keep the accessories on the normal belt. i don't know how much room you have in front of the engine/crank pulley though.
Old 05-07-2010, 01:15 PM
  #53
dirtydodgeon22s's Avatar
how well will a positive displacement like these mentioned here hold up to a cogged setup?
Old 05-07-2010, 02:56 PM
  #54
GFYS and STFU
Spoolin's Avatar
Those OAD pulley's are pretty trick!!
Old 05-07-2010, 08:07 PM
  #55
DrX
DrX's Avatar
The blowers could be on a cogged belt now - not separate though. Accessories are on their own belt. Not sure what issues could arise from a cogged setup though, particularly with 2 blowers, and with hanging all that load way out off the front of the crank.
Cog drive:
http://www.youtube.com/watch?v=ntZCL...eature=related
I reclocked the tensioner slightly today so that at the stop there is just a hair between the 2 belt sections. Engine off the tensioner is wound up 3/4 of the way to the other stop. If that isn't enough, then the whole setup has to be changed anyway. I was already surprised to get over 20 psi out of an 8 rib. Will find out how it works out when I get my hood back.
Old 05-16-2010, 12:21 PM
  #56
acethedragon's Avatar
hey drx. any update on the avy yet. hope you got it straightened out
Old 05-16-2010, 12:42 PM
  #57
DrX
DrX's Avatar
Waiting to get my hood back. I hit WOT a couple of times when I went to drop it off and the belt stayed put, so I am keeping my fingers crossed.
Old 05-31-2010, 10:44 AM
  #58
ZO6 LandRocket's Avatar
Originally Posted by DrX
Had to build a controller.
How can I get one? Trying to run a dual throttle body setup on my 2008 ZO6.
Old 05-31-2010, 07:03 PM
  #59
DrX
DrX's Avatar
At this time, we would have to custom build one for you.
Old 05-31-2010, 07:18 PM
  #60
11 sec. Truck Mod
TIM Z's Avatar
Glad the belt is staying put Doc.
Kudos to you for building one incredable machine!
Quick Reply: Re-arranged my throttle bodies.......
