reduced engine power
8 Second Club
P2101 - Throttle actuator control module range
DTC P2101
Circuit Description
The commanded throttle position is compared to the actual throttle position based on accelerator pedal position (APP) and possibly other limiting factors. Both values should be within a calibrated range of each other. The engine control module (ECM) continuously monitors the commanded and actual throttle positions. This DTC sets if the values are greater than the calibrated range.
DTC P2101
Circuit Description
