Reduced engine power??? Help educate me
An easy way to check for leaks is to take the outlet off the turbo. Then put something with an air line into the charge pipe. I used a small cup with a fitting in it. The tighten the clamp down and charge about ten psi into it. Doing this I found all of my injectors were slightly cocked and were leaking air. It will also help to find any leaky charge pipe connections.
P0068 map or Maf throttle position
P0101 mass or volume air flow a circuit range / performance pending
P0106 map / barometric pressure range
P0137 o2 low volt bank 1 sensor 2
P0157 bank 2 sensor 2
P2270 o2 lean bank one sensor 2
P2272 02 lean bank 2 sensor 2
Seems like a tune issue. And the rear o2s are plugged in but just tied up outta the way
Thanks for the tips turbhoe
Your rear o2's won't cause any issues with it running. They are just there to check the status of your cats. Just have them turned off in the tune. The 101 and 106 cause the 068. You have to figure out if it's a leak causing the faults and if all is right tune them out. But out of boost it should not throw those codes. Do you have a blow off valve? If so it may be opening under vacuum/low throttle conditions. If this is the case it will be bypassing the maf causing in metered air.
ARC
57
02-21-2022 10:54 AM
bsgiffor
07-19-2015 11:14 AM
