Result on my Turbo 6.2
#61
Its not drastically harder to tune, but it is mechanically more complicated and more difficult to achieve a good level of reliability and towing performance. The underhood heat is not trivial, it is very significant.
Sounds like you have your mind made up though, good luck!![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
#62
I have a gauge for that
From just about every perspective. A blower is extremely simple by comparison, it is basically an intake manifold swap with a longer belt and you are done. With an intercooled turbo system you have additional plumbing from cold side from the compressor to the intercooler and back to the intake, and plumbing from the exhaust to the turbine then out of the engine bay. EVERYTHING will have to be routed clear of the hot exhaust or else you will have issues with stuff melting, and may anyway from simple proximity. Wraps and coatings help, but picture your engine bay as a massive oven and you get the idea. Most drag races are 10-12 seconds at most, but pulling a load up a hill you are talking minutes on end at elevated temperatures. By elevated I mean EGTs are easily 500F hotter than with an equivalent supercharged setup.
A rear mount turbo would be better in this regard, but then you have to worry about oil return pumps (which always have problems it seems), additional length of piping, and I hope you dont mind waiting a week for the turbo to get going or maxing out very quickly.
And before you say "diesels pull all day with a turbo" or "the ford ecoboost is turbod", yea, those are true, but both systems are factory designed by a team of engineers with millions of dollars in R&D to make sure everything is good. This is not comparable to a turbo retrofit for a system that was not designed for it.
If you want good reading on the subject, I recommend this book:
#64
And please know I don't want to debate the wisdom of using a turbo. But when these generalities are thrown out (not recent posts) about turbo assumptions, I just need to ask about where the info comes from. If everyone took things at stated value, we would all be driving the same vehicles. Thanks for the input!
#65
I completely get that and that's valid for sure.
#66
If you want good reading on the subject, I recommend this book: https://www.amazon.com/Turbocharging-Performance-Handbook-Motorbooks-Workshop/dp/0760328056/ref=sr_1_6?ie=UTF8&qid=1529700029&sr=8-6&keywords=turbocharger+book
Wouldn't a supercharger setup generally have an intercooler to plumb?
Why the hotter egt's with turbo over supercharger? Where does the heat come from?
#67
Glad you enjoyed the book. He is specifically talking about heat inside the combustion chamber. We are mainly talking about radiant heat from the exhaust and turbine parts.
Supercharger would have an an intercooler and heat exchanger, but 3/4" rubber hoses are much easier to deal with than turbo pipes.
In a supercharger the crankshaft is powering the compressor, in a turbo it is the exhaust gas. The energy that is otherwise transferred through the crank and belt takes the form of energy in the exhaust gas for a turbo to drive the turbine which is mechanically linked to the compressor.
GXPJAY
02-13-2022 08:15 AM
GXPJAY
01-27-2016 11:45 AM
05GMC4.8
08-07-2015 09:55 PM
