Roush S/C help....?
Old 02-23-2013, 10:03 AM
03sierraslt's Avatar
I am sure you could make one, as mentioned what should it be made out of?
Old 02-23-2013, 10:27 AM
BlewSilverado's Avatar
Its a rubber o ring type of gasket.
Old 02-23-2013, 10:56 AM
TX Tahoe Z71's Avatar
Bead of black RTV, or wait 120 days for the proper gasket. I would get the proper gasket anyway, then throw it in once it arrives and clean off the RTV with a brush and rubbing alcohol.
Can you post up a picture of where the gasket goes or a picture of what the gasket looks like? That would help.
Old 02-23-2013, 02:02 PM
jiar577's Avatar
+1
How much is the gasket? Just curious
I waited close to a couple of years to install my blower, don't see a big deal waiting 120 days
Just kidding as I was going nuts waiting to install it, unfortunately things weren't going my way back then and I was really close to selling the blower. I'm glad I didn't and the wait was more than worth it.
Old 02-23-2013, 06:50 PM
11 sec. Truck Mod
TIM Z's Avatar
Just measure the ID and OD of the ring in the manifold , shouldn't be hard to find an Oring for it .
Old 02-23-2013, 07:05 PM
Post up some pictures of where it goes so we can get some better ideas of what you need.
Old 02-23-2013, 11:22 PM
MB2008LTZ's Avatar
I hope this works......pics
Roush S/C help....?-2013-02-23_23-50-32_94%5B1%5D.jpg
Roush S/C help....?-2013-02-23_23-50-23_687%5B1%5D.jpg
Roush S/C help....?-2013-02-23_23-51-18_501%5B1%5D.jpg
The 1st pic is of the upper intake where I need the gasket/o-ring
2nd pic shows where there is a gasket/o-ring type seal in place around the cooler (squared area)
3rd pic is the bottom side of blower where the bypass valve mates to the upper intake.
Old 02-24-2013, 01:22 AM
Just measure it then google XXmm o-ring. I tried it just now with random sizes and got results for every one (10mm, 11mm, 18mm, 28mm). They are cheap, so if you aren't sure, just order a few different sizes. Just my $.02
Old 02-24-2013, 09:09 AM
jiar577's Avatar
As mentioned, that should be easy to find.
If I remember right, that gasket is the same material/thickness as the gasket around the cooler in the second pic. Just measure its thickness and measure the internal diameter and you're set.
Old 02-25-2013, 12:35 PM
jdgoodcat's Avatar
I believe it was a 4.5mm o-ring. Most part houses should have an assortment of sizes. Hope this helps
Quick Reply: Roush S/C help....?
