Roush supercharger eaton tvs 1900 gmt900
#51
I was actually thinking about picking up one of those chevy lumina vans, you know the one that looks like a pull-behind vacuum cleaner? Do a custom mid-engine setup with one of those dime a dozen 4.8L engines and turbo it. Nobody would expect to be roasted at a stoplight by a 1990s soccer mom van...
#52
FormerVendor
I know you live and learn, and installing things twice can make you a good mechanic, But like I said I cant afford those extra screw ups. And I am really close with my tuner who installs all my stuff, most of the time I am there watching. I would help if I could without getting trouble from his insurance co.
My truck is my DD so i cant just park it for a 3-4 days or a week while I install something slowly to make sure its done right..
I Pretty much do my own installs unless it involves internal work or rear end work.. Im sure I could do cam installs and things If I could let my truck sit and take my time doing the install with the proper tools then Id be good to go.. I am only 19 turning 20 so I still have lots of learning to do..
#53
FormerVendor
In case anyone didnt hear the results,
quez82's truck made approx 480 rwhp with this kit on a mustang dyno (1100SE eddy current loaded to 5250lbs). That was on a hot pull right after marking several pulls before it. Kit was a real clean easy install other than needing to fab a little holddown for the original map sensor which was no biggie.
Cool it off for awhile sitting on the dyno and youd see 500 rwhp on a mustang dyno. Really solid numbers.
calsdad
06-14-2023 11:07 PM
1900, 2009, 62, eaton, gmc, gmt900, kit, roush, sierra, silverado, specs, supercharged, supercharger, superchargers, tvs
