Roush TVS 1900 New Install....No Boost
#43
Yep, there is no factory boost port, at least mine didn't have one. Taped in the manifold for boost gauge.I think I have some picture floating around here somewhere. BTW mine made just under 7lbs of boost almost instantly at wot from an idle.
#44
I'm using the "factory" intake boost side tap that came on the unit. I have my MAP and Kenne Bell sensors on the same line. I have checked the line and there aren't any leaks.
When you state that you were getting 4.5 to 5 lbs, at what RPM did you get that pressure? I get about 3 to 3.5 until I hit about 5000 RPMs, then it climbs to 5 lbs. Like I said above, it makes a lot of sense that I am using up all of the air until the motor get's inefficient, then it climbs. But I keep hearing that with a stock internals 6.0 that I should have about 6 lbs.
I already pinned the crank, so the balancer isn't spinning. I am going to look for the idler pullies to get a better wrap around the SC pulley just to make sure. Is 100mm the best size for maximum wrap?
#45
Can you post some pics of where you put a port in to measuring boost and the machined snout. If its possible id like to get those measurement of the snout. Have you found out your boost issue? Thanks guys
#48
Got a 2.75" pulley from southfloridapulleyhq.com. I haven't sent out the snout for machining yet, but hope to soon. It's a keyed pulley, so I will have to get the shaft cut for that.
Problem with low boost was partially from the belt slipping. I put belt conditioner on the belt and installed an HD tensioner which fixed the problem. With my cats out, I still only make about 3-5 lbs of boost, so I expect 8-10 with the new pulley. I also installed a quieter muffler which added about .5 lbs due to lower flow.
I travel a lot, so I don't have much time to play with the truck. I will try to post pictures when I do get the snout machined and new pulley installed.
