Roush TVS on a NBS
#31
I found the adapters from w w w. fuelinjectorconnection . com. Be warned though, some of the wires came out of the pins. They were not crimped very well. I ended up pulling the connectors apart and recrimping then soldering the wires as well. I think if i had it to do all over i would just buy the ends and splice them onto my existing harness. I just thought the adapter was a good idea if I ever returned to stock.
The TB adapter came from kenne bell. It had to be modified though. I thought I was getting a bolt on adapter but it wasn't drilled for the 4 bolt TB flange. I was able to make it work. It wouldn't be to hard to just make on out of say 3/8 or 1/2 alum plate.
I think I'm going to go ahead an get the bigger 4 bolt TB and try the dr x adapter from torque rush
#32
Thanks for the info, the injector adapters make sense as I don't plan to keep the truck forever.
By the way, I see several adapters in there, any idea of which ones do I need? Mini Delphi to Uscar? I'm a complete newbie on this stuff lol
#35
All the parts searches show the NNBS water pump but I have the NBS round log fuel rails.
#36
Thank You! I am trying to figure out what I am getting myself into before I tear into it. I am putting this on my 2007 H2 which is a hodge-podge of model year change parts. For instance, my 07 actually has the 2008 exhaust on it that Y's into a 3.5 y-back system.
#37
OK, mine comes up about 45 degrees and is straight. Thanks for the info.
Gmc_sierra
09-13-2015 10:02 PM
