Roush TVS Pullies
#91
Mod with training wheels
Yeah I will be making them out of stainless. I've heard bad things come from making pulleys out of aluminum. Probably spin right off the shaft. I could turn it on a lathe. Balancing wouldn't be an issue as long as I don't remove the part from the lathe once I begin machining it until its finished. Grooves would be a bit of a pain with the stainless, but not impossible. It would just take a while. But honestly, I will just work with a CNC program to make them repeatable. Only difference is changing the OD radius to get a different pulley size, which doesn't take long.
You thinking about that phenolic spacer? I have been pondering it myself I've checked clearance, looks to be plenty of room under there. Almost 2 inches I'd guess.
#92
and about the clearance.. yes partially the phenolic spacer and if i could id like to run a nitrous plate in there to so im not spraying through the supercharger... 2" would be awesome. im thinking an inch only would be good. max 3/4 for the nitrous plate and 1/4 to 1/2 of phenolic should be fine i think.
