Roush TVS1900 question/help
Mod with training wheels
And how do I know what's the right one? What ohms should I look for?
I don't have a clue working on trucks, but I did a cam & spring swap last year with info I read here so this should be a piece of cake lol
I almost forgot, any chance that you remember what size drill did you used to install the IAT sensor? Drill material (in case it's needed)?
Thank you all for your help.
But anyway, you just need to get a multimeter and check the resistance of the wire you splice into in the harness. This is just to make sure you have the right tan wire so you aren't scratching your head wondering what happened when its just the wrong wire. Resistance should be less than 1 ohm since it will be a straight wire.
Did you cut that black wire or just splice into it? I believe they run off the same +5v input, so if you cut that to wire in your IAT sensor, your MAF won't be getting any power. You'll need it unless you are running a speed density tune.
When i ohmed mine out it showed the solid tan wire but when i tied it in it threw a maf code and a iat code so i soldered the tan back and tied 2 the tan with black chaser and no more iat code and the sensor is reading according to my scanner but i still have a maf code!? I tried a new maf sensor and still throws the code as soon as truck starts. Anyone have any ideas!?
Thanks smokeshow that was the prob! Now the only other prob i have is when i start the truck up it pulls 60+psi but after it runs for a little but or i hit the gas the pressure drops down to around 44psi!? I had tried hooking up a keene bell boost a pump that kb had given me with the kit but it was only putting out 6.75volts 2 the pump so i soldered the factory pump feed wire back together and this is happening, doh! Whats the best way 2 check voltage 2 the fuel pump without probing a wire?
