S400-75 t6
I seen full boost right around 3200 rpm with my 6l looks just like a kbracing set up but I have a 3.5 dp into 4in exhaust z06 cam stock heads I was running 14 psi
thats pretty good for a big turbo. i need to finish up the tuning and see were i see full boost at with this big housing. if anything ill just upgrade to the 480 with 1.10 ar since i plan to go with a bigger motor soon! what are your plans as far as the 408 and what internals are you using? considering a 408 aswell
I'm picking up a kit from Texas speed everythings forged I'm upgrading the rods and pistons to better ones including the bearings and balanced there kits are priced pretty good I believe it's a eagle crank I'm going with scat h beam rods and weisco pistons compression should be right around 9.5 to 1
LS1Tech Sponsor
Well it sounds like you have the 83mm turbine wheel. It will have some very high back pressure on the 408 on 14psi. The 1.32 a/r units have the 96mm turbine wheel witch would work great on the 408.
Well pulled the motor apart number 7 crapped out and took a chunk out of the piston so looks like the cylinder is good so it's getting forged rods and pistons and getting put back in
