Safe boost with no meth?
#21
#22
no he means the steam vents. You have 1 on each end of the head, so a total of four. early ls1's had them all venting to the radiator. Our trucks usually have the front 2 connected and then going through the TB then to the radiator. The rear 2 are blocked off. You need to vent those rear 2 just like the front 2 or you will get hot spots and could burn up the rear cylinders. That is the reason #7 failures are so prevalent in these motors
#23
I don't have 4 on my 03 truck. I have only one on the rear of driver side valve cover which is connected to the L92 intake that I swapped to.
L92 intake/TB do not have any other connections, so, I capped the vent on the front of the valley cover.
gavin2005
09-13-2015 09:04 PM
