School me on chemicals.
#21
I'm with Roger, that bracket looks like it would be easy to make.
It is hard to tell, but can you inject water/meth anywhere under the intercooler? I think the roots style water/meth injections are not working well because the rotors heat everything up.
I wonder what that intercooler looks like, can you find pics of one?
On a side note, how are you able to get that much air through an LS7 throttle body? Mine won't handle the radix 112 with a 2.6 pulley. It looks like you will be moving a lot mote air than that.
They just didn't give enough room to go direct port meth.
Fabricating a new bracket will be another option, then it needs new manifold bolts to work. So I shall ponder.
How much does a spacer reduce IAT's by under boost?
#25
I may be wrong but it looks to me that adding a spacer and longer support bracket would move everything straight up and improve geometry and add additional belt wrap.
Vortec350ss
01-12-2016 10:36 PM
drummer0415
11
10-24-2015 08:16 PM
lukn4trbl355
10-21-2015 11:19 PM
