Should I bother to go from 7 to 10psi?
truck is in the sig. with the warm temps im down from 8 to 7-7.5psi. Im getting some ID850 injectors soon and was thinking of going to 10psi. This would require a meth kit and at $500+ for a Alky kit im wondering if its worth it. I was told I would see maby 24hp going to 10psi. Should I be running a meth kit with what I have now? I dont think I will have to get a retune @ $120 just for the injectors. Mike said he will check the tune with the injectors just to make sure everything right. I assume just a data log off the dyno. I will need a retune for 10 and meth so it would cost $800 maby more just to go up 3psi.
He's not going to see a 75hp increase from 2-2.5 psi on that Maggie. If your going to go through the hassle and expense of adding more boost and installing a meth kit, then go 12 psi with meth and a retune. Then you will notice a big difference from where your at now and the added $ spent will show some nice results.
Adding just 2-2.5# will not net 75hp but if you remove the cats and add meth then that should get you pretty close to 75hp. I would still just go to a 12# pulley with meth and a retune. Just my 02 cents.
