Should I be running different plugs with a 6.2L @ 8psi
Old 01-23-2013, 05:31 AM
TheBurlyMan's Avatar
I was also under the impression that the TR6 plug was the one to run? Ran them in my procharged GTO with success? Do TR6's not fit these trucks ?
Old 01-23-2013, 05:41 AM
03sierraslt's Avatar
As mentioned above, a BR6EF is a non projected TR6. Non projected is better for boost. Below 10-12 psi a 6 should be fine, if more then that on pump gas I would go to a 7. (General rule) you still should read the plugs to see how they are burning.
Old 01-23-2013, 08:54 AM
TX Tahoe Z71's Avatar
Non-projected tip dissipates heat better because of the shorter ground strap. Gap should be 0.03-0.035" for your setup. I run 0.035" and haven't had a problem.
Non-projected tip on the left, projected on the right. (not my photo, I stole it)
Old 01-23-2013, 09:09 PM
lglowe's Avatar
I ran tr6 with 16 ish psi and it did just fine. But a lot of meth helps
Old 01-24-2013, 05:14 PM
MB2008LTZ's Avatar
I find it difficult to think that shorter ground strap in a combustion chamber that has a high compression explosion going off like every half of a second going down the road at 2000 +/- rpms is going to run cooler enough to make difference...but what do I know?
Old 01-25-2013, 09:01 AM
10 Second Club
02 BLK WS6's Avatar
If it were my setup, I'd run a BR7EF and learn how to read your plugs.
Old 01-25-2013, 12:32 PM
JCunningham's Avatar
I could use a better education on reading plugs. never had a engine that I has to put non stock plugs in
Old 01-25-2013, 07:59 PM
the 7 is a colder plug right? This is a daily driver that sees -* temps if that maters.
Old 01-25-2013, 08:06 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
At 8 psi, and a typical/conservative tune, there is no way you will need a plug that is 2 steps colder than stock (the 7). Stick with the BR6EF and you'll be just fine, and not have any issues.
If you ever decide to get aggressive with the tune, and crank up the boost, then things change.
Old 01-25-2013, 08:12 PM
im running 170hp over stock + ill be adding the headers so around 200hp over stock? stock plugs would be a ngk 5 then?
Quick Reply: Should I be running different plugs with a 6.2L @ 8psi
