Side mount Magnacharger or Powedyne?
Old 09-20-2005, 09:01 AM
Mort's Avatar
Cool
Originally Posted by COLDZ71
Those are ACDELCO, correct...snip
TR55 are made by NGK.
Old 09-20-2005, 04:25 PM
COLDZ71's Avatar
Gotcha did a quick search and realized my mistake. Better order a set soon cause I just sent payment to QuickSilverado for his old Magnacharger.
Old 09-20-2005, 06:47 PM
quicksilverado's Avatar
You can also use Autolite AR103. Make sure they are AR103 and not A103.
Old 09-21-2005, 03:34 PM
03sierraslt's Avatar
I have had great luck with NGK's I run TR6's
Old 09-21-2005, 03:35 PM
zippy's Avatar
if you're going to go with a powerdyne you want the gear drive version. with either of the two choices though i'd recomend adding an intercooler.
Old 09-21-2005, 06:54 PM
COLDZ71's Avatar
Was the intercooler an option from Magnacharger or do you have to custom fabricate one. I wouldn't know where to start if I had to fabricate my own setup. Does anyone know how to go about building one?
Old 09-21-2005, 07:28 PM
Much easier to use meth kit rather than trying to fab up an I/C. Unless you are good at that type of fab work. 8 months out of the year you should be fine without either one with the cool air you have up there.
Old 09-22-2005, 05:25 AM
COLDZ71's Avatar
Wow. Never really thought of it that way. Its already 40 degrees in the morning up here. Does a Meth Kit work similar to a N2O system? Do you have to spray it when you want it?
Old 09-22-2005, 07:27 AM
It adds octane and lowers tha IAT. I have mine set to come on at 5 psi. It is easy to install. Took about 45 minutes. All you have to do is install a resevior or use the windsheild washer tank. Run a few wires and install the nozzle before the throttle body. I have a SMC kit I bought off the board used for 165.00.
Old 09-22-2005, 02:45 PM
zippy's Avatar
custom only, like this...
Quick Reply: Side mount Magnacharger or Powedyne?
