Silverado Turbo Build Questions
Hey guys, I'm collecting some parts to boost my 2003 Silverado and I have a few questions. I bought a Huron Speed T6 kit and was making a list of other things I need and wanted some input on the things I need or if I am missing anything. The truck has a 5.3 with 241 heads, TBSS intake, and a summit 8709R1 cam. It's also got a t56 magnum and 4.56 gears.
So far I have:
Huron Speed T6 kit with a VSRacing S480 AERO T6 1.32 Race Cover Turbo
Huron Speed HS60v2 wastegate
Huron Speed HS50v2 BOV
The kit comes with the hot side, cold side and pretty much everything to plumb it.
I need injectors and was wondering if these would work with the TBSS intake and fuel rails?
Injector Connection Injectors
I was going to buy the Huron Speed fuel pump assembly with the wiring harness but only run 1 walbro 450 for right now until I need another pump. I don't exactly have any power goals... But I would like a decently fast truck. ( I know that's subjective)
Will my stock fuel lines work? Do I need to upgrade to -8 feed -6 return right away?
What are you guys running for boost referenced fuel pressure regulators? I was thinking this one unless someone has a different brand that's better for whatever reason?
Aeromotive Fuel Pressure Regulator
I've read people us the cobalt SS MAP sensor. Would this be the one?
I know I'll need a muffler and some tubing but I can figure out what I want for that later. Am I missing anything you guys can think of? Also if anyone has suggestions for better parts or something that would work better for me, please let me know!
Thanks in advance!
So far I have:
Thanks in advance!
DateNight (Today)
