SilveradoL33 at the track
Old 04-19-2009, 04:56 PM
  #21
00Silv4.8's Avatar
y did you go to a return style? I would like to do away with mine if it werent such a pain in the ***
Old 04-19-2009, 05:07 PM
  #22
speedaddict's Avatar
19psi on that run? Very nice run btw. Gives me hope with my big o 22" rims....
Old 04-19-2009, 05:15 PM
  #23
1989k1500's Avatar
No, down more around 14 or 15.
Old 04-19-2009, 05:16 PM
  #24
mike06tork's Avatar
real good times for a big truck. what fuel system are you running... injectors, pumps, FPR ect.
Old 04-19-2009, 05:52 PM
  #25
1989k1500's Avatar
Its an A1000 on a return system with stock fpr and 60lb injectors.
Old 04-19-2009, 06:03 PM
  #26
mike06tork's Avatar
^^^ A1000 aeromotive right but how dose he has it conected to the oem tank is that A1000 in line or what. and damm on the stock FPR! its running real good.
Old 04-19-2009, 06:08 PM
  #27
LS1Tech Sponsor
hellbents10's Avatar
We modded the stock bucket and use it just as a sump now. The A1000 is just in front of the tank on the frame rail pulling from the sending unit and running the stock feed line. Evap is removed and the evap line is used to return fuel to the top of the sending unit via a bulk head with some -6 line. The stock 03' regulator seems to be working very well with this setup. He also has had no troubles at or a little below a 1/4 as far as I know.
Old 04-19-2009, 06:14 PM
  #28
mike06tork's Avatar
^^^ is the stock pump feeding the A1000 or its just the A1000 feeding the motor itself. Silveradol33 truck isnt Flex-fuel wih the flex-fuel pakage.
Old 04-19-2009, 06:47 PM
  #29
nonnieselman's Avatar
very very nice!!!
Im guessing the lift and tires hurts you a lil on top end? Aerodynamic killer ha..
Old 04-19-2009, 06:58 PM
  #30
silveradol33's Avatar
No we took out the stock pump, its not a flex fuel truck.
Quick Reply: SilveradoL33 at the track
