Sleeper is alive! 535 rwhp & 589 rwtq @ 7lbs
Old 09-04-2008 | 08:49 PM
built408's Avatar
Good numbers... Time for more boost
Old 09-08-2008 | 01:02 AM
wheeelie's Avatar
Originally Posted by 1BadAction
I used a GM factory "low washer fluid" indicator blank out of the 93 for a "low meth" idiot light. Everything is integrated into factory fuse blocks and my custom harness, that still isnt completed.
excellent idea. it just makes sense
Old 09-10-2008 | 01:50 AM
Y2KLimited's Avatar
Originally Posted by TurboBerserker
I really like the Alky Control kits. Julio Dom is the owner of the company and I can't say enough good things about him.
It depends on how much meth you spray, but look at it this way: meth chemically intercools your air charge, and adds extra fuel at the same time. I'd tell Julio what you've got and what you want to run in terms of boost and let him spec out the kit for you.
I run dual m15 nozzles with my kit and have one of his "super pumps".
sounds like my setup in the vette with teh paxton. I also run an alkycontrol dual nozzle setup with the biggie pump, the sts car was on a single nozzle.
20 pounds with 93 octane at 9.5-1 compression work for ya?
and yes the IAT sensor is right behind the meth nozzles if it goes hot, it yanks timing...
Old 09-17-2008 | 03:07 PM
408 Sleeper's Avatar
Here are the final numbers. Safe tune at 15lbs with 91 octane, no meth.
605 & 647 flat power curve from 5,000 to 6,000. This I can be happy with. I'm sure if it was a 2wd with street tires the totals would be even higher.
Old 09-17-2008 | 07:08 PM
Spoolin's Avatar
GFYS and STFU
You gained 70 hp and 58 tq with 8lbs more boost?? That doesn't sound right at all! And your power curve is only 1,000 rpm's? That's gonna be hard to use IMO.
Old 09-17-2008 | 08:14 PM
kingots2004's Avatar
Originally Posted by 408 Sleeper
Okay, I wil look into the meth a little more. My computer does not have a feature to retard timing in relation to a higher IAT temp. It will however add or subtract fuel in relation to IAT temps. Back to the meth, lets say I can run 15lbs with 91 octane. How many additional lbs should the meth allow me to run? Also which kit would be the best for a twin turbo truck? Thanks
i know its not a truck but on my grand national i run 17lbs with pump gas and run 27 lbs with meth.its all in the tune.i run a devils own kit dual nozzel but razor kits are what most buick guys have.also some run smc kits or devils own kits.its got a cpt66 turbo and a big front mount
Old 09-18-2008 | 01:21 AM
I made an error on my first post. The first set of numbers were at 10 lbs of boost. The power curve is quite linear. It peaks just under 5,000 and rather than falling right off, it continues on an almost flat line to 5,800 of so. I will have the dyno sheets soon and post them.
NateBower002
10-27-2015 02:04 PM
lukn4trbl355
10-22-2015 12:19 AM
Wolftrk99
10-02-2015 09:17 AM
Closer_2001
09-24-2015 10:15 PM
bluestang50
09-21-2015 09:36 AM
