snow performance?
snow performance?
Has anybody used this kit by snow performance http://www.snowperformance.net/proddetail.asp?prod=auto023 ???
It uses your MAF for progressive control. I am trying to find the best kit any inputs would be awsome. One more thing how do you figure out how high you can crank the boost?
Originally Posted by seadoo
if you want the best, for not that much more...
you need alkcontrol's system
lets put it this way, Parish8 uses it. and so does MANY boosted cars/trucks in the country
The Devil's Own kit is a great kit also. It uses a SMALL microprocessor variable controller that is MAP based, which is better then a MAF setup in my option, MAF are too easy to max out. And I don't think they will work on are truck as are MAF work off of Hz and not volts. You better check on that befor droping the dough.
I have a Snow Performance Stage 2 MAF setup installed on my truck. Not tuned yet but that's another issue. It varies injection using MAF voltage from a selected start voltage to a selected voltage where it is pumping at 100%. Takes some time to tune but it's a very accurate and consistent setup. There is also a boost referenced controller available too.
I have the Snow kit with boost referenced progressive controller. I am going with the Alky Control kit soon. The snow kit is OK, but my lines started leaking at the fittings and I had to use GOOP to seal them, now they look like **** and there is rust inside the globs of GOOP. I would be OK if I could find a way to get fittings and stainless line like the alky control kit uses so I dont have to worry about leaks. I tried getting SS lines and AN fittings but tore my hands up trying to get the fittings on the lines and getting the fitting to match up with the exit of the pump and fitting for the nozzle. Wasted money. It wouldve been cheap to buy the Alky Control kit. Im sure other kits work as does the Snow kit. If you want the best package you will pay for it.
