So 10psi is max on a stock engine...
#64
Originally Posted by 1SlowHoe
Parish8,
Any idea as to the timing on that run? (at 19-20psi)
I would have bet good money the stock GM pistons would have broke under the pressure regardless of how good the tune was.
No meth?
No meth?
and unless I am reading wrong, that was on stock pistons.......
#65
single digit dreamer
the valve covers were pulled to swap springs and that is the only work that has been done to the engine. no meth. strait 118 octane fuel. 16deg of timing, we tried more but it didn't seem to want it so we took it back out. here is a chart with a little more info.
#66
Nice AFR.. that's what I target..11.2 to 11.4.....
I am surprised on the timing though.... My truck feels like a dog at 16-18 degrees on pump gas (93 Octane)..... 22-23* seems to be the sweet spot on my logs... guess I need to get this thing back on a dyno to look at the actual curve.... last time I was on a dyno was Feb. 2006 after the head/cam swap....
I also agree on the spring swap... I bumped shifts to 5800 on stock springs and saw a bit of valve float... added the stage 2 heads and dual springs that issue went away...
#68
remember this run is on a dynojet so a prety short pull. in the 6sec pull the iats went from 97deg up to 123deg. on the track we will probably start with a little lower iat and we will have lots of air being pushed thru the intercooler but the run will be at least 10sec long so not sure what the iat's will be at the end of the run.
#69
#70
Originally Posted by FlaBouy
That's what is kicking me in the ***... those IAT's are what I am seeing now that I installed the aftercooler..... a WOT pull through about 120 mph nets me about 127-129* IAT's...... maybe it is the meth that is wanting the additional timing.....
