spraying intercooler
Originally Posted by Slowhawk
Don't waste your $$. You sig says you have meth.If it's 100% meth your all good.Spraying the intercooler is for the imports.
Hey I spray my intercooler! But pretty much just for when Im towing , and towing in traffic. Plus i had mine before the meth. IM NOT A ****** RICER. He he J/K im not offended.
If the nitrogen was sprayed into a fog it would be ok, but any more concentrated may cause things to shrink
then get frozen moisture between fittings,
then have water between fittings after warming up and possibly blow off some connections??
Sounded like a rocket scientist answer when it popped into my head, must be the beer talkin!
yes im spraying 100% meth, but i dont have a intercooler on yet and my maf is take out timeing. i think the intercooler and meth will help out a lot. just a thinking of things to try if it does not work. thanks for the info
If you run 100% meth injection you can get away with pretty high IATs before your timing suffers if you do your own tuning. I see 150*+ with 24* timing and no knock. Lower IATs are always better and will make more power, but at the cost of an additional system on the truck.
