spun my crank :(
spun my crank :(
noticed a loud chirping sound yesterday, thought it was my tensioner bearing
so i replaced it. turns out it wasnt that so i turned the truck on and got under it.. i noticed the crank wobbled a little so i sprayed some wd40 and it stopped the chirp. anything i should look for when i pull off the crank pulley??
any info would help, thanks!! 01 4.8 with a mp112 on 12 psi, btw
you're hearing the harmonic balancer slipping on the crank itself
you must pin the crank
critical mass with a 2.8" for sure totally dude
take the balancer off and use some fine emery cloth on it befor re-install and pin it already
ps buddys truck has had a magna doodle wet noodle for 10 years
no slippy ........................operator error?
What he said. I think??? F_ck I'm not really sure... What did you say again?
as well pully spinning on the hub. you mentioned it got quieter with WD40
(WD40 WTF over?) kysilverado? I got the lowly sierra it didn't come with any KY
